11 years agoarriaII GX DDR3 assignment
DDR3(SSTL15)(MT41J64M16 – 8 Meg x 16 x 8 banks) is assigned to bank7A of ArriaIIGX (EP2AGX125) in altera evaluation board.
I'm planning to assign same DDR3 as this to bank3A(Bottom side). I judge that it's better to add DDR3 to the BANK3A because RUP0,RDN0 exists in BANK3A, and this is related to OCT. A power supply relation is established as follows. This is also indicated on attachment. RUP0=1.5V、VREFB3AN0=0.75V、VCCIO3A=1.5V、VCCPD3A=2.5V DDR3 clocks (DDR3_CLK_P (N)) are assigned to a differential output pin (DIFFIO_TX_B13p (n)). DQS0 groups(DQ0-7) are assigned to BIO2. DQS1 groups(DQ0-7) are assigned to BIO1. address,commands are assigned to BANK3A. I use DDR3 memory MT41J64M16 ? 8 Meg x 16 x 8 banks for example. Compilation is successful just in case. Is my setting right?3 Replies
--- Quote Start --- Just FYI, it is not necessary to have the DDR3 in Bank3A because the ArriaII supported OCT on all I/O pins. You can calibrate the I/O banks with any of the OCT cal blocks available in the device provided the VCCIO of the I/O bank with the pins using cal OCT matches the VCCIO of the I/O bank with the cal block and its associated RUP and RDN pins --- Quote End --- irish-san Thank you. I changed device to 780 pin device from 1152 pin device(Because of cost). And I cannot assign ddr3 in bank3.(Lack of a pin) So I assign ddr3 to bank4 and 7(I use 2 ddr3 devices). Bank7 has RUP/RDN pin.Bank4 has no RUP/RDN pin. RUP(BANK7) is connect to 1.5V.VCCIO of BANK4 and 7 is 1.5V(VCCPD=2.5V). It is same VCCIO voltage,so I can calibrate BANK 4 and 7 with the cal block(BANK7) associated RUP and RDN of BANK7. Is it right? - Altera_Forum
If it compiles without any issues, it should be fine. You can also consult the pin out files on Altera's website just in case.
