11 years agoarriaII GX DDR3 assignment
DDR3(SSTL15)(MT41J64M16 – 8 Meg x 16 x 8 banks) is assigned to bank7A of ArriaIIGX (EP2AGX125) in altera evaluation board. I'm planning to assign same DDR3 as this to bank3Aᦀ...
11 years agoJust FYI, it is not necessary to have the DDR3 in Bank3A because the ArriaII supported OCT on all I/O pins. You can calibrate the I/O banks with any of the OCT cal blocks available in the device provided the VCCIO of the I/O bank with the pins using cal OCT matches the VCCIO of the I/O bank with the cal block and its associated RUP and RDN pins
