11 years agoarriaII GX DDR3 assignment
DDR3(SSTL15)(MT41J64M16 – 8 Meg x 16 x 8 banks) is assigned to bank7A of ArriaIIGX (EP2AGX125) in altera evaluation board. I'm planning to assign same DDR3 as this to bank3Aᦀ...
11 years ago --- Quote Start --- Just FYI, it is not necessary to have the DDR3 in Bank3A because the ArriaII supported OCT on all I/O pins. You can calibrate the I/O banks with any of the OCT cal blocks available in the device provided the VCCIO of the I/O bank with the pins using cal OCT matches the VCCIO of the I/O bank with the cal block and its associated RUP and RDN pins --- Quote End --- irish-san Thank you. I changed device to 780 pin device from 1152 pin device(Because of cost). And I cannot assign ddr3 in bank3.(Lack of a pin) So I assign ddr3 to bank4 and 7(I use 2 ddr3 devices). Bank7 has RUP/RDN pin.Bank4 has no RUP/RDN pin. RUP(BANK7) is connect to 1.5V.VCCIO of BANK4 and 7 is 1.5V(VCCPD=2.5V). It is same VCCIO voltage,so I can calibrate BANK 4 and 7 with the cal block(BANK7) associated RUP and RDN of BANK7. Is it right?
