Arria10GX PCIE to RSU implementation
- 5 years ago
I can access the link and download the example design. Kindly try to access using different browser or clear the browsing data history before downloading the design.
KhaiY
Hi @KhaiChein_Y_Intel ,
regarding of " Could you share what does functionality upgrade mean? " question?
=> actually what I mean is :
we want to download & burn new FPGA Image into our A10 board, through PCIe i/f.
I see there're some RSU Example is through “i2c” or "uart" , not sure whether RSU can go through PCIe ? if yes, where can find the example project ?
Thanks for reply
For Intel Arria 10 devices, use Partial Reconfiguration over Protocol instead of CvP Update. You can use the PCIe bus to perform Partial Reconfiguration.
In CvP, you partition your design into two images: core image and periphery image.
- Periphery image (*.periph.jic) — contains general purpose I/Os (GPIOs), I/O registers, the GCLK, QCLK, and RCLK clock networks, and logic that is implemented in hard IP such as the JTAG interface, PR block, CRC block, Oscillator block, Impedance control block, Chip ID, ASMI block, Remote update block, Temperature sensor, and Hard IP for PCI Express IP Core. These components are included in the periphery image because they are controlled by I/O periphery register bits. The entire periphery image is static and cannot be reconfigured.
- Core image (*.core.rbf) — contains logic that is programmed by configuration RAM (CRAM). This image includes LABs, DSP, and embedded memory. The single static core image may include PR reconfigurable regions.
- Reconfigurable region — This region can be programmed in user mode while the PCIe link is up and fully enumerated. It must contain only resources that are controlled by CRAM such as LABs, embedded RAM blocks, and DSP blocks in the FPGA core image. It cannot contain any periphery components such as GPIOs, transceivers, PLL, I/O blocks, the Hard IP for PCI Express IP Core, or other components included in the periphery image.
- Static region — This region cannot be modified.
If you refer to the PCIe timing sequence in CvP mode, you will see that PCIe link is inactive during Periphery image configuration. PCIe link training happens after the Periphery image configuration is completed. Therefore, you can use the PCIe link to perform Core image configuration only. For Periphery image configuration, you have to use the conventional method such as JTAG.
intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_cvp_prop.pdf
KhaiY
- JET602005 years ago
Contributor
thanks for detailed explanation.
unfortunately we FPGA doesn't divided into peri + core 2 parts, our FPGA has only one image, And actually we want is sth like "RSU over PCIE" . right ?
Contributor
Hello @KhaiChein_Y_Intel ,
Sorry but this problem is still there.
I searched and found today Intel FPGA WiKi has released a new example project which may be what I'm seeking, see below :
[ Design Example: Intel Arria 10 FPGA Remote System Update via PCI Express*
The problem I'm facing is: when I happily click the " design example link " at " Intel Arria 10 FPGA Remote System Update via PCI Express* | Design Store for Intel® FPGAs ", The page link (https://fpgacloud.intel.com/devstore/platform/20.4.0/Pro/intel-arria-10-fpga-remote-system-update-via-pci-express/) just show [
403: Access Denied
Where Can I donwload this " " Intel Arria 10 FPGA Remote System Update via PCI Express* | Design Store for Intel® FPGAs " example project ?
Thanks for help again !
- KhaiChein_Y_Intel5 years ago
Referring to Table 92 Configuration Schemes and Features of Intel Arria 10 Devices
A10 support PCIe CvP configuration but it is for core image configuration only.
KhaiY
KhaiY
