Arria10GX PCIE to RSU implementation
- 5 years ago
I can access the link and download the example design. Kindly try to access using different browser or clear the browsing data history before downloading the design.
KhaiY
Could you share what does functionality upgrade mean?
The support feature for Arria 10 is as below
Link: https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/pcie-support.html (Device Selection)
If you go to the User Guide section, you can find the document for each supported feature. You will find the steps to generate the example design in the document.
KhaiY
- JET602005 years ago
Contributor
Hi @KhaiChein_Y_Intel ,
regarding of " Could you share what does functionality upgrade mean? " question?
=> actually what I mean is :
we want to download & burn new FPGA Image into our A10 board, through PCIe i/f.
I see there're some RSU Example is through “i2c” or "uart" , not sure whether RSU can go through PCIe ? if yes, where can find the example project ?
Thanks for reply
- KhaiChein_Y_Intel5 years ago
For Intel Arria 10 devices, use Partial Reconfiguration over Protocol instead of CvP Update. You can use the PCIe bus to perform Partial Reconfiguration.
In CvP, you partition your design into two images: core image and periphery image.
- Periphery image (*.periph.jic) — contains general purpose I/Os (GPIOs), I/O registers, the GCLK, QCLK, and RCLK clock networks, and logic that is implemented in hard IP such as the JTAG interface, PR block, CRC block, Oscillator block, Impedance control block, Chip ID, ASMI block, Remote update block, Temperature sensor, and Hard IP for PCI Express IP Core. These components are included in the periphery image because they are controlled by I/O periphery register bits. The entire periphery image is static and cannot be reconfigured.
- Core image (*.core.rbf) — contains logic that is programmed by configuration RAM (CRAM). This image includes LABs, DSP, and embedded memory. The single static core image may include PR reconfigurable regions.
- Reconfigurable region — This region can be programmed in user mode while the PCIe link is up and fully enumerated. It must contain only resources that are controlled by CRAM such as LABs, embedded RAM blocks, and DSP blocks in the FPGA core image. It cannot contain any periphery components such as GPIOs, transceivers, PLL, I/O blocks, the Hard IP for PCI Express IP Core, or other components included in the periphery image.
- Static region — This region cannot be modified.
If you refer to the PCIe timing sequence in CvP mode, you will see that PCIe link is inactive during Periphery image configuration. PCIe link training happens after the Periphery image configuration is completed. Therefore, you can use the PCIe link to perform Core image configuration only. For Periphery image configuration, you have to use the conventional method such as JTAG.
intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_cvp_prop.pdf
KhaiY
Contributor
thanks for detailed explanation.
unfortunately we FPGA doesn't divided into peri + core 2 parts, our FPGA has only one image, And actually we want is sth like "RSU over PCIE" . right ?
