Arria V-Quartus 18/18.1 time quest constrains.
I have problems, with a Arria V-Quartus 18/18.1 and time quest constraints. It seems quartus does not apply the constraints file. The same Project Works properly with a cyclone III and Q13.1.
- KhaiChein_Y_Intel
What is the value in the hardware?
- JOter
I haven't the numeric results, we didn't anotate them. We tested it with wide range of data output delays (for example from 0 to 8ns)
You must take into acount that the same project works properly with a cyclone III and Q13.1. So we are looking for a problema in our "Q18 and Arria V" Project, or in Q18 compiler.
Best regards
- KhaiChein_Y_Intel
Hi, The value that you see in the Timing report is the worst case scenario. Is the output delay in the hardware exceed the value in the timing report? Thanks. - JOter
I'm sorry but I didn't see your message. At the end I didn't use any "output_delay", I only used the clock phase shift.
I try to summarize the case. I used the next configuration:
create_clock -name PSRAM_CLK -period 16 [get_ports {PSRAM_CLK}]
create_generated_clock -name vt_PSRAM_CLK -source [get_ports {PSRAM_CLK}] -divide_by 1 -multiply_by 1 -phase 180
set_output_delay -clock {vt_RAM_CLK} 2 [get_ports {RAM_A* }]
Signal meaning:
PSRAM_CLOCK: RAM mem. clk generated in a FPGA-PLL
RAM_A: RAM mem, addr.I
Both signals were monitoring with one oscilloscope. The delay between both was almost constant for any "set_output_delay" value, quite different to the programmed value.
