JOter
7 years agoArria V-Quartus 18/18.1 time quest constrains.
I have problems, with a Arria V-Quartus 18/18.1 and time quest constraints. It seems quartus does not apply the constraints file. The same Project Works properly with a cyclone III and Q13.1.
JOter
6 years agoI'm sorry but I didn't see your message. At the end I didn't use any "output_delay", I only used the clock phase shift.
I try to summarize the case. I used the next configuration:
create_clock -name PSRAM_CLK -period 16 [get_ports {PSRAM_CLK}]
create_generated_clock -name vt_PSRAM_CLK -source [get_ports {PSRAM_CLK}] -divide_by 1 -multiply_by 1 -phase 180
set_output_delay -clock {vt_RAM_CLK} 2 [get_ports {RAM_A* }]
Signal meaning:
PSRAM_CLOCK: RAM mem. clk generated in a FPGA-PLL
RAM_A: RAM mem, addr.I
Both signals were monitoring with one oscilloscope. The delay between both was almost constant for any "set_output_delay" value, quite different to the programmed value.
