Arria V-Quartus 18/18.1 time quest constrains.
I have problems, with a Arria V-Quartus 18/18.1 and time quest constraints. It seems quartus does not apply the constraints file. The same Project Works properly with a cyclone III and Q13.1.
- KhaiChein_Y_Intel
Hi JOter,
What are the error messages? Could you elaborate?
- KhaiChein_Y_Intel
Hi JOter, Any updates? Thanks- JOter
There are not errors. The problema is that the signal are delayed as spected.
The signal re: RAM_CLK (CLK) and OUTPUT 0 (counter)
We tested both signal in one scope, and we didn't notice any change between them changing the OUTPUT_DELAY constraints.
Remenber we checked it also using a C III, and in this case we got the spected signal.
We used the next constrains commands:
set_output_delay -clock vt_RAM_CLK -max [expr $RAM_tsetup + $RAM_BDb_max - $RAM_CLK_DLY_MIN] [get_ports {OUTPUT[0]}]
set_output_delay -clock vt_RAM_CLK -min [expr -$RAM_thold + $RAM_BDb_min - $RAM_CLK_DLY_MAX] [get_ports {OUTPUT[0]}]
And
set_output_delay -clock RAM_CLK -max [expr $RAM_tsetup + $RAM_BDb_max - $RAM_CLK_DLY_MIN] [get_ports {OUTPUT[0]}]
set_output_delay -clock RAM_CLK -min [expr -$RAM_thold + $RAM_BDb_min - $RAM_CLK_DLY_MAX] [get_ports {OUTPUT[0]}]
Best regards
- KhaiChein_Y_Intel
Can you check if the constraints are being ignored under 'Ignored Constraints'? Can you provide the timing report for both design?
- JOter
I send you both projects, so you can obtain all information.
- JOter
- JOter
- KhaiChein_Y_Intel
Hi JOter,
I checked the AV_OUTPUT_DELAY_TEST using Timing Analyzer, the output delay is as what we set in the .sdc file.
max 3ns and min 2ns.
- JOter
Thanks for your answer.
The problem is when we checks the ouput signal whith one oscilloscope, the output delay between both signals doesn't change using differents
Best regards
- KhaiChein_Y_Intel
Do you mean that the result in Timing Analyzer is different from the hardware result?
- JOter
Yes, the results seems to be the same independently of the constrains assignement.
Best regards
