15 years agoArria II rx_signaldetect
I am using the Arria II demo board (125 version) and have ALTGX configured in basic mode. I turned on 8B/10B to enable the rx_signaldetect output. The rx_signaldetect is stuck high all the time no matter what I do. I followed the couple of reset sequences suggested on the Altera site and looked at the recommendations on the Stratix IV manual with no success. I have tried with a signal present, without a signal preset, with the loop back board on the HSMC connector, with our own HSMC board, again with no success. I tried with manual LTR/LTD and automatic mode. Did anyone run into this or similar issue? Thank you!5 Replies
what about for the cyclone IV GX in 11.0?
Hello! I can't download 0.63 patch for windows for Quartus 10.1. Can You say, where I can get it?
I checked the link again today and there was an update to the solution related to a bug in 11.0. I applied the suggestion and now it works.
Dino,
Thank you for the reply! It would be nice if the links to the updates worked! :) I have to move on to a different project. When/if I come back to this, I will deal with it then. - Altera_Forum
You might want to check this out ...
http://www.altera.com/support/kdb/solutions/rd04042011_919.html
