16 years agoArria II GX Development Boards Unused i/os
I am wondering what would be the safe state of the unused i/os on the arria ii gx development board. What I worry about is when I do not use a particular i/os it may still be connected on the board ...
16 years agothe PCG is good if you're designing a board, but if you're using a devkit i'm not sure its all that helpful.
setting unused I/O to input with weak pullup shouldn't break anything, but it might set (unused) peripherals into unknown modes or other unexpected behavior. then again if you aren't using that particular feature you probably don't care what mode its in. you could take a look at the some of the included example designs to see what they have done with unused pins.
