16 years agoArria II GX + DIMM = no more than 12 HSTL/SSTL output or bi-directional pins are allo
I'm trying to get my EP2AGX45 (572 package) Arria II GX to interface with a DIMM. I've run into an apparent limitation of 12 SSTL signals per I/O bank. It seems i will have to move up to the top devi...
15 years agoI didn't try with differential DQS. To see, what's the problem with 572-pin Arria II, I would have to implement a test design. I was originally referring to the reported "12 SSTL signal limitation" which is known as a problem of missing OE-group assignments. It may be the case, that Arria II has additional restrictions, that don't allow to implement a 64-Bit RAM interface with 572-pin package. If so, it would be a chip design or Quartus flaw.
I implemented however a DIMM interface with only two 1.8V banks of 1120-pin Arria, which should give an almost comparable number of available memory pins.
