16 years agoArria II GX + DIMM = no more than 12 HSTL/SSTL output or bi-directional pins are allo
I'm trying to get my EP2AGX45 (572 package) Arria II GX to interface with a DIMM. I've run into an apparent limitation of 12 SSTL signals per I/O bank. It seems i will have to move up to the top devi...
15 years agoThe problem is usually brought up by not correctly defining the output enable groups for the bidirectional memory data path. If you follow the suggested design flow for the DDR controller, tcl files containing the respective settings are automatically imported to the design assignments. The point is, that all bidrectional data and dqs pins of a DDR RAM are set as input or output simultaneously. Thus, the limitation for maximum allowed number of output or bidirectional pins in a bank does not apply. Quartus is using the attribute output enable group to mark those pins, that are driving simultaneoulsy.
