Arria 10 series has dedicated 3 CS for the flash devices.
What is the use case of 3 Chip select of the external flash device ?
- YuanLi_S_Intel
Hi SB S,
The number of chip select available means that the device is capable to connect to the number of external flash devices. You may have different configuration file store in each flash devices so that your FPGA can be reprogrammed easily.
YL
- SB_S
So By default we connect CS_0 to the flash device. If we have 3 flash devices and if FPGA wants to fetch the configuration file from 2nd flash , how it asserts the CS_1 ?
- YuanLi_S_Intel
Hi SB S,
By default, it will configure the FPGA with configuration devices connected to nCS[0]. Then later on, user can reconfigure the FPGA in user mode with configuration data in another configuration devices connecting to nCS[1] or nCS[2] with a host.
YL
