Arria 10 series has dedicated 3 CS for the flash devices.
Hi SB S,
The number of chip select available means that the device is capable to connect to the number of external flash devices. You may have different configuration file store in each flash devices so that your FPGA can be reprogrammed easily.
YL
- SB_S7 years ago
So By default we connect CS_0 to the flash device. If we have 3 flash devices and if FPGA wants to fetch the configuration file from 2nd flash , how it asserts the CS_1 ?
- YuanLi_S_Intel7 years ago
Hi SB S,
By default, it will configure the FPGA with configuration devices connected to nCS[0]. Then later on, user can reconfigure the FPGA in user mode with configuration data in another configuration devices connecting to nCS[1] or nCS[2] with a host.
YL
- SB_S7 years ago
Hi can you please reply for this query ?
- SB_S7 years ago
In the above document it says , the FPGA tries to load the configuration file 3 times if it fails initially. Does this mean , it asserts the cs_0 first then if don't find a valid file ,assert the cs_1 , then cs_2 .. Is it so And if we have valid configuration file in all the flash devices and if i need to select the second flash , how can user pull the CS_1 ? It has to be from FPGA right ?
