Arria 10: Remote Update may brick FPGA and Factory Fallback won't work
we have observed some critical failures when doing tests with various potential error scenarios concerning a remote Update of the FPGA bitstream in the attached SPI Flash device.
We could repeatedly trigger cases, when the FPGA internal fallbeck mechanism to the factory load does not work. We do not use any bitstream encryption.
Test scenarios:
- Erased flash & partially programmed application load image --> Fallback mechanism works as expected
- Invalid application load image location, i.e. start of application load is shifted by1-10 Byte (Manually induced error scenario) --> The reprogramming sequence starts but never completes and no fallback to the factory load is performed. => The FPGA is completely unresponsive unless programmed via JTAG
It is obvious, that the 2nd scenario might be a more exotic error scenario, however we require a robust setup and have to make sure, that the FPGA remains accessible under any circumstances, so we need the Factory Fallback mechanism to work reliable!
As a best guess I could assume it might be related to this Note in 1.3.1. Remote System Configuration Mode that the factory fallback mechanism won't work for Arria 10 FPGAs if the last 576 Bytes of the bitstream are corrupted.
Note: The fallback to the factory image does not work under the following conditions: If the last 576 bytes of an unencrypted application image bitstream are corrupted. Intel recommends that you examine the last 576 bytes of the unencrypted application image before triggering the application image configuration.
But I have noticed that the binary images of the FPGA bitstream vary in size. So there is no way to check explicit memory locations for these 576 Bytes. Is there any way to identify this section?
My Questions:
- Why is the factory configuration fallback mechanism not working in the above described scenario? The Factory load image is valid!
- What method does intel recommend to reliable make the factory fallback mechanism work?
- How can I examine/validate a FPGA bitstream in flash memory before executing it?
Thanks a lot for any help
Best regards
Fabian
- FabianL
is there any advise for this topic?
Fabian
