Arria 10: Remote Update may brick FPGA and Factory Fallback won't work
Hi Fabian,
1- For the CRC_ERROR, I am still checking internally what the exact trigger condition for this CRC error. May I confirm how you make the change of application image start address? For example, did you set the start address at 0x00 to 0x1F in the flash as 0x01000020, but when generating the JIC file, you set the application image address as 0x01000018?
2- For the Watchdog question, may I know how you enabled the watchdog?
According to the 1.3.1.1. Remote System Upgrade State Machine of the IP user guide, "In the DTA mode, the watchdog timer is disabled by default. You cannot enable the watchdog timer in the initial or first application image loaded upon powering up the device".
When you generating the JIC file, if you set the boot page to the application image page (for example, Page_1) to allow the FPGA to boot directly from application image (DTA), then in this condition, the watchdog is actually not enabled when the first application image loaded.
Xiaoyan
