arria 10 lvds serdes
Hi @HortumNecmi @LLCC ,
I'm facing the same issue, but I already have the bits connected to an input port on one end and to an intermediate pin on the other end. I have this piece of code on my toplevel HDL and I'm not sure what is still missing.
-- group the block/polarization data together for the serdes IPs adc_if_0x_rx_in <= T1_X_FCLK & T1_R8X_I & T1_R8X_Q & T1_X_FCLK & T1_R7X_I & T1_R7X_Q & T1_X_FCLK & T1_R6X_I & T1_R6X_Q & T1_X_FCLK & T1_R5X_I & T1_R5X_Q & T1_X_FCLK & T1_R4X_I & T1_R4X_Q & T1_X_FCLK & T1_R3X_I & T1_R3X_Q & T1_X_FCLK & T1_R2X_I & T1_R2X_Q & T1_X_FCLK & T1_R1X_I & T1_R1X_Q; -- some code in between -- LVDS SERDES adc_if_0x : component lvds_tile port map ( inclock => FPGA_REFCLK_ADC, -- adc_sample_clk 50 MHz pll_areset => core_reset, pll_locked => adc_if_0x_pll_locked, rx_in => adc_if_0x_rx_in, rx_out => adc_if_0x_data_out, rx_coreclock => adc_if_0x_rx_coreclock, -- 50 MHz (SERDES Factor 7) rx_dpa_reset => adc_if_0x_rx_dpa_reset, rx_dpa_locked => adc_if_0x_rx_dpa_locked, rx_bitslip_ctrl => adc_if_0x_rx_bitslip_ctrl, rx_bitslip_reset => adc_if_0x_rx_bitslip_rst );
The lvds_tile component was defined and added to the project. I'm not getting any syntax error. I'm using a 24 channel approach (see the concatenation at line 2) with a serialization factor of 7. But I'm getting errors like the error given below (I get it for all 24 bits of channel[]) when I try to compile on Quartus Pro 21.3. I've verified that the Platform Designer connects 'adc_if_0x_data_out' to an intermediate block as well, so it's not optimized away either.
I'd be appreciated if you could give me a hand here.
Cheers
Error(129015): Output port RXDATA on atom "adc_if_0x|lvds_tile|core|arch_inst|channels[23].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a cyclone10gx_io_serdes_dpa primitive, is not legally connected and/or configured
Info(129016): Output port RXDATA[0] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[1] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[2] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[3] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[4] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[5] is disconnected, but the Compiler expects this output port to be connected
Info(129016): Output port RXDATA[6] is disconnected, but the Compiler expects this output port to be connected
Info(11951): Module instance "adc_if_0x|lvds_tile|core|arch_inst|channels[0].dpa_fifo.ioserdesdpa.serdes_dpa_inst", which is a twentynm_io_serdes_dpa primitive and belongs to an ALTLVDS interface, should have a bus width of exactly 7 connected to TXDATA port.
- FvM1 year ago
the error message sounds like your intermediate block doesn't provide an actual connection for SERDES rx_out. Can you try to export at least some channels to top level pins for test?- anonimcs1 year ago
Contributor
I have done it, and it seems like the errors I got are related to the connection of 'rx_dpa_locked'. But feels odd because the compiler complains about the rx_out's connection whereas the errors are gone when I make the dpa_locked connection of the exported qsys component open.
