civey0207
3 years agoArria 10 Low Latency 40G Ethernet Fails to compile with VHDL
I'm trying to evaluate the Low Latency 40G Ethernet core in a VHDL based design. The settings of the core are the same as the example design. I've instantiated the ATX PLL that comes with ...
- 3 years ago
Hi civey0207,
I think you see the error in synthesis stage might due to the IOPLL instance in Intel Arria 10 design is not connected to a valid REFCLK signal.
Zi Ying
ZiYing_Intel
3 years agoHi civey0207,
Can share your .qar file here? So that I can try debug the issue from my side.
Zi Ying
