AVolo2's avatar
AVolo2
3 years ago
arria-10-gx dev ttack won't install on x86_64
could you advise which exactly OS to install on x86_64 in order for intel dev stack script to work correctly, please? Tried with ubuntu 18,20 with various kernel versions 5.4, 5.8 - it won't work
What OS is supported?
    • AVolo2's avatar
      AVolo2
      Thank you for following up
      So it is not possible to run the hello world example on the PAC without a paid license? Without the Quartus Standard /Pro Software?
      You do not provide a free trial developers license to confirm things are working at all?
      Which OS will support installing the PAC acceleration stack [ dev] installation script in a way it will be possible to run the diagnostic/ hello world example to confirm the PAC card works at all?
      -BR
      AV
  • AR_A_Intel's avatar
    AR_A_Intel
    Based on my understanding, Alternative you could apply an Intel 90-Day Evaluation License use with Quartus Pro/Standard. Login to Intel® FPGA Self Service Licensing Center and request the Quartus evaluation free license here https://licensing.intel.com/
    1) Go to Sign up for Evaluation or Free licenses
    2) Select Intel® FPGA EVALUATION-LIC
    3) # of Seats is always 1
    4) Check the T&C box
    5) Add the required options
    6) Click Get License button
    The license will be sent to email that you register with
    AR_A_Intel
    We have not heard from you and I hope that my last note clears up this matter. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
