AVolo2
4 years agoarria-10-gx dev ttack won't install on x86_64
could you advise which exactly OS to install on x86_64 in order for intel dev stack script to work correctly, please? Tried with ubuntu 18,20 with various kernel versions 5.4, 5.8 - it won't work
W...
AR_A_Intel
4 years agoHi
Arria 10 device is supported in Quartus Prime Pro and Standard Edition Software. Refer here
- AVolo24 years ago
Thank you for following up
So it is not possible to run the hello world example on the PAC without a paid license? Without the Quartus Standard /Pro Software?
You do not provide a free trial developers license to confirm things are working at all?
Which OS will support installing the PAC acceleration stack [ dev] installation script in a way it will be possible to run the diagnostic/ hello world example to confirm the PAC card works at all?
-BR
AV
