10 years agoArria 10 GX configuation time vs. PCIe requirement
I've been charged with figuring out a configuration scheme for our Arria 10 design that will incorporate a PCIe interface. I've attached an image of what I've come up with
There is a 100ms configuration requirement if you are using PCIe. So to get my device to configure (270K GX part 10AX027H3F35), I have learned that basically we'll have to do a x32 configuration scheme running at 100MHz between our configuration host (MAXV with parallel flash loader) and the FPGA. This should load our FPGA in 38.4ms. The problem I am having is that I have to use FLASH storage for the bit file, and I just can't see how we can pull data out of the FLASH fast enough to feed the HOST => FPGA interface. I'm doing a 32 bit interface to the flash as well, using two 16 bit FLASH parts, and the "Parallel Flash Loader IP Core User Guide" says that the flash_clk speed is half the core source clock (125MHz/2 =62.5Mhz). Doing rough math, even at the most optimal burst rate:- 122,591,622 bits for Arria 10 10AX027H3F35.
- 32 bit interface from FLASH to HOST
- 32 bits from HOST to FPGA configuration interface
- 122,591,622/32 bits = 3830988 cycles @ 62.5MHZ (optimum BURST rate - not realistic full time) = 3830988*16nS = 61mS.
- The above 61ms < 100mS. Sounds fine, but read on.
- 351,292,512 bits for Arria 10 10AX1157N2F35.
- 351,292,512/32 bits = 10977891 cycles @ 25MHZ - yes their config HOST clk is 50Mhz (optimum BURST rate - not realistic full time) = 10977891*40nS = 439mS.
- The above 439ms >> 100mS. This makes PCIe use impossible.
1 Reply
To satisfy the 100ms PCIe boot time you need to first configure the FPGA with a small image (short boot time) that brings the PCIe links up. You then need to use partial reconfiguration, typically via Configuration via Protocol (CvP) to boot the remainder of the device.
Look through the arria 10 device overview (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/arria-10/a10_overview.pdf). Search through it for "Configuration via Protocol". Happy New Year, Alex
