Giz2020
4 years agoArria 10 flash security
Hello, We're using Arria 10 with EPCQ device, and looking for solutions to protect the EPCQ content.
The EPCQ is used for holding both the configuration bitstream and also other data.
Configur...
- 4 years ago
Regarding to question 2, no we cant access to the AES modules.
YuanLi_S_Intel
4 years agoHi, yes you may encrypt the new design file with the same key. In fact, you can only program the design file encrypted with the same key.
- Giz20204 years ago
Thank you for your reply.
I didn't mean a new design file, but other data that we store on the flash.
During operation, nios read/write data from/to the flash. Is there an option to encrypt this data using the existing mechanism that deals with flash encryption (Design secure feature), or we need to use another encryption block to be in the middle between nios and flash?
