15 years agoArray Problem
Hi again,
When i compile the following code it eats all my logic. I'm pretty sure its a problem with the use of arrays.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity VERTICAL_COUNTER is
port
RESETn : in std_logic;
CLK100MHz : in std_logic;
COUNTER_ABLE : in std_logic := '0';
CAM_FRAME_VALID : in std_logic := '0';
CAM_LINE_VALID : in std_logic := '0';
CAM_DATA_VALID : in std_logic := '0';
CAM_DATA : in std_logic_vector (7 downto 0) ;
READ_FROM_ARRAY : in std_logic := '0';
WRITE_ENABLE : out std_logic := '0';
DATA_VALID : out std_logic := '0';
DATA_OUT : out std_logic_vector (7 downto 0);
-- ARRAY_ERROR : out std_logic := '0';
-- COLUMN_NUMBER : out std_logic_vector (10 downto 0);
OUTPUT_amp_max : out std_logic_vector (7 downto 0);
OUTPUT_amp_06 : out std_logic_vector (7 downto 0);
OUTPUT_amp_n1_greater : out std_logic := '0';
OUTPUT_position : out std_logic_vector (7 downto 0)
end entity;
architecture rtl of VERTICAL_COUNTER is
type array_type_8bit is array (0 to 1279) of std_logic_vector (7 downto 0);
type array_type_1bit is array (0 to 1279) of std_logic;
signal array_amp_max , array_amp_06 , array_position : array_type_8bit ; --:= (others => (others => '0'));
signal array_amp_n1_greater : array_type_1bit ; --:= (others => '0');
signal counter : integer range 0 to 1280 := 0;
signal line_counter : integer range 0 to 255 := 0;
signal read_counter : integer range 0 to 1280 := 0;
signal counter_max : integer range 0 to 2047 := 0;
signal data_loaded : std_logic := '0';
signal send_data : std_logic := '0';
signal buff_line_valid : std_logic := '0';
signal out_amp_max : std_logic_vector (7 downto 0) := (others => '0');
signal out_amp_06 : std_logic_vector (7 downto 0) := (others => '0');
signal out_greather : std_logic := '0';
signal out_position : std_logic_vector (7 downto 0) := (others => '0');
begin
prog_adr : process (CLK100MHz) begin
if rising_edge (CLK100MHz) then
data_loaded <= '0';
counter <= counter;
read_counter <= read_counter;
WRITE_ENABLE <= '0';
DATA_VALID <= '0';
DATA_OUT <= (OTHERS => '0');
if COUNTER_ABLE = '0' then -- reset condition
send_data <= '0';
counter <= 0;
read_counter <= 0;
else -- COUNTER_ABLE = '1'
if CAM_FRAME_VALID = '1' then -- or data_loaded = '1' then
read_counter <= 0;
send_data <= '1';
buff_line_valid <= CAM_LINE_VALID;
if buff_line_valid = '1' and CAM_LINE_VALID = '0' then
line_counter <= line_counter + 1;
counter_max <= counter;
counter <= 0;
end if;
if CAM_DATA_VALID = '1' then -- and data_loaded = '0' then
data_loaded <= '1';
if CAM_DATA >= array_amp_max(counter) then
out_amp_max <= CAM_DATA;
out_amp_06 <= std_logic_vector( to_unsigned( to_integer( unsigned( CAM_DATA )) * 16
+ to_integer( unsigned( CAM_DATA )) * 2
+ to_integer( unsigned( CAM_DATA )) + 16 , 13))(12 downto 5) ;
else
out_amp_max <= array_amp_max(counter);
out_amp_06 <= array_amp_06 (counter);
end if;
if CAM_DATA > array_amp_06 (counter) then
out_greather <= '1';
else
out_greather <= '0';
end if;
if CAM_DATA <= array_amp_06 (counter) and array_amp_n1_greater(counter) = '1' then
out_position <= std_logic_vector (to_unsigned(line_counter,8));
else
out_position <= array_position(counter);
end if;
else
if data_loaded = '1' then
counter <= counter + 1;
array_amp_max(counter) <= out_amp_max;
array_amp_06(counter) <= out_amp_06;
array_amp_n1_greater(counter) <= out_greather;
array_position(counter) <= out_position;
end if;
end if;
else
counter <= 0;
line_counter <= 0;
if send_data = '1' then
WRITE_ENABLE <= '1';
if read_counter >= counter_max then
send_data <= '0';
elsif READ_FROM_ARRAY = '1' then
read_counter <= read_counter + 1;
DATA_VALID <= '1';
DATA_OUT <= array_position(read_counter);
array_amp_max(read_counter) <= (others => '0');
end if;
end if;
end if;
end if;
end if;
end process;
end rtl;
Explanation: When frame valid (image is read in) i'm doing some actions. 1) searching the max amplitude in every column. 2) calculating MAX value * 0,6 (see an other topic i started) 3) Searching the calculated value in the column and storing the position (line number). When frame is not valid, i can read out the array (RAM) My last problem with arrays was when i made the whole array empty so it didn't used RAM but logic. Q: Why is it making logic this time ? Anyone has a better way to write this code? (Less resources and still readable, cauze i'm still learning)3 Replies
With some syntax issues getting figured out, i have it working like a
charm!!( used dual ram template ) Thx josby and till my next question. - Altera_Forum
Thx! I'll should do some reading :)
I think the compiler has a problem to synthesize a Ram because of following code:
In these lines you are asking from the MLAB RAM to deliver a result in one clock cycle, which it can't. The Read Address is first registered before being applied to the RAM-cells, which delays the result by one clock cycle. So the compiler uses logic cells to build that section, requiring 1280 * 8 LEs per array. I suggest you read about the internal RAM blocks. I never have the compiler infer a RAMs for me, I always either use the MegaWizard, but most often I instantiate a RAM component directly (peeking into what the MegaWizard generates helps to understand what generics to apply).if CAM_DATA >= array_amp_max(counter) then . . . out_amp_max <= array_amp_max(counter); . . .
