15 years agoArray Problem
Hi again, When i compile the following code it eats all my logic. I'm pretty sure its a problem with the use of arrays.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_st...
15 years agoI think the compiler has a problem to synthesize a Ram because of following code:
if CAM_DATA >= array_amp_max(counter) then
out_amp_max <= array_amp_max(counter);
. . . In these lines you are asking from the MLAB RAM to deliver a result in one clock cycle, which it can't. The Read Address is first registered before being applied to the RAM-cells, which delays the result by one clock cycle. So the compiler uses logic cells to build that section, requiring 1280 * 8 LEs per array. I suggest you read about the internal RAM blocks. I never have the compiler infer a RAMs for me, I always either use the MegaWizard, but most often I instantiate a RAM component directly (peeking into what the MegaWizard generates helps to understand what generics to apply).
