15 years agoArray make's logic or uses BRAM?
Hi I'm working on a project with a cyclone III ( EP3C10F256C8).
In the project en monitoring with a camera. I need to write a code who finds the position of the brightest pixel in the image. I made an array for the full lengt (1280 columns) of 8 bit. When I recieve the first line of the camera, i compare the value of the corresponding column with a value of a register who memory's the maximum value (brightest pixel). If it is a higher (brighter) value , then i place the number line (position) in a position_register. If the camera has sended the image is read out the position_register. The problem si that the compiler doesn't use BRAM and the logic generated for the process is to big for the device. How can i force it to use BRAM ? (Working in Quartus II v8.0) The code i wrote:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity VERTICAL_COUNTER is
generic
Write_adress : std_logic_vector (22 downto 0) := "000" & x"00000"
port
RESETn : in std_logic;
CLK100MHz : in std_logic;
CAM_DATA_VALID : in std_logic := '0';
CAM_DATA : in std_logic_vector (7 downto 0) ;
CAM_FRAME_VALID : in std_logic := '0';
CAM_LINE_VALID : in std_logic := '0';
COUNTER_ABLE : in std_logic := '0';
DATA_VALID : out std_logic := '0';
DATA_OUT : out std_logic_vector (7 downto 0) ;
FRAME_WRITE_ADR : out std_logic_vector (22 downto 0);
WRITE_ABLE : out std_logic := '0'
end entity;
architecture rtl of VERTICAL_COUNTER is
signal buff_CAM_LINE_VALID : std_logic_vector (1 downto 0) := (others => '0');
signal send_data : std_logic := '0';
signal line_counter : integer range 0 to 255 := 0;
signal column_counter : integer range 0 to 1279 := 0;
signal max_column : integer range 0 to 1279 := 0;
type array_type is array (0 to 1279) of unsigned (7 downto 0);
signal array_position , array_amplitude : array_type;
begin
FRAME_WRITE_ADR <= Write_adress;
prog_adr : process (CLK100MHz) begin
if rising_edge (CLK100MHz) then
buff_CAM_LINE_VALID <= buff_CAM_LINE_VALID(0) & CAM_LINE_VALID;
if CAM_FRAME_VALID = '1' and COUNTER_ABLE = '1' then
send_data <= '1';
if CAM_LINE_VALID = '1' then
if CAM_DATA_VALID = '1' then
column_counter <= column_counter +1 ;
if unsigned (CAM_DATA) >= array_amplitude(column_counter) then
array_position(column_counter) <= to_unsigned (line_counter, 8);
array_amplitude(column_counter) <= unsigned (CAM_DATA) ;
end if;
end if;
end if;
if buff_CAM_LINE_VALID = "10" then
line_counter <= line_counter + 1;
if column_counter > max_column then
max_column <= column_counter;
else
max_column <= max_column;
end if;
column_counter <= 0;
end if;
else -- cam frame valid = 0
if send_data = '1' then
DATA_VALID <= '0';
WRITE_ABLE <= '1';
if column_counter >= max_column then
send_data <= '0';
max_column <= 0;
else
DATA_VALID <= '1';
DATA_OUT <= std_logic_vector (array_position(column_counter));
end if;
else
WRITE_ABLE <= '0';
line_counter <= 0;
array_amplitude <= (OTHERS => (OTHERS => '0'));
array_position <= (OTHERS => (OTHERS => '0'));
end if;
end if;
end if;
end process;
end rtl;
K, Thx for the help!
If you really have to clear the memory, you have to do it one by one.
Indeed, just found it by trying and came here to tell about my results and saw your post.
Do you have a ID how to clear it ? Or do i need to do it sequentially (one by one)? Compilation time reduced with 28 min :) - Altera_Forum
The problem is that you reset the memory. No internal ram can be reset, so it cannot infer a RAM from the behaviour you have specified. So it uses logic instead (and probably takes a long time to compile)
Remove the reset code (the bit that sets all locations to 0) and try again. - Altera_Forum
No Reply's are coming so let me explain it in an other way.
A Camera sends its pixel from left to right and top to bottom. (Like you read a text). I need to find the brightest pixel in a column (Vertically). Therefor i need to memorize the maximum value for each column. I use 2 array's : Position array and Amplitude_array - Amplitude array witch holds the maximum value of the pixel for each column - Position array witch holds the position of the pixel for each column At start both array's are filled with '0' First line is read -> I compare the value of the first image_pixel with the value that is stored in the amplitude_array. If the read value is more than the stored one: Than overwrite the stored value with the new one in the amplitude_array. Also store the linenumber in the position_array. If not -> Do nothing to the array's I need to do this for 1280 columns (image size is 200x1280) The result: An array with the position of 1280 pixels (brightest) I wrote some code but the problem is that it generates logic to find the brightest pixel 1280 times. I need code that that generates logic, to find the brightest pixel and use it 1280 times in stead of making it. EXPLANATION OF MY CODE:
Declaration Arraysignal send_data : std_logic := '0'; signal line_counter : integer range 0 to 255 := 0; signal column_counter : integer range 0 to 1279 := 0; signal max_column : integer range 0 to 1279 := 0; type array_type is array (0 to 1279) of std_logic_vector (7 downto 0); signal array_position , array_amplitude : array_type;
Need to wait untill DATA_VALID for camera. If valid add index (column) with one. T'check if New pixel is brighter than stored one If so -> Store position (line number) to array_position -> Store new pixel in array_amplitude For each new line there is a counter that increases line_number. Why doe's this code generates so dam'n much logic ? Plz Helpif CAM_DATA_VALID = '1' then column_counter <= column_counter +1 ; if (CAM_DATA >= array_amplitude(column_counter)) then array_position(column_counter) <= std_logic_vector (to_unsigned (line_counter, 8)); array_amplitude(column_counter) <= CAM_DATA; end if; end if; - Altera_Forum
If more explanation is needed ,plz say!
Thx anyhow.
