15 years agoArray make's logic or uses BRAM?
Hi I'm working on a project with a cyclone III ( EP3C10F256C8). In the project en monitoring with a camera. I need to write a code who finds the position of the brightest pixel in the image. ...
15 years agoThe problem is that you reset the memory. No internal ram can be reset, so it cannot infer a RAM from the behaviour you have specified. So it uses logic instead (and probably takes a long time to compile)
Remove the reset code (the bit that sets all locations to 0) and try again.
