Aria V Display Port core sometimes disconnected
Hi dlim
I managed to create and compile successfully the example project. since my PCB has only one lane of DP Rx I had to make some changes and customize the example design. attached are updated top.v, pinout table and Qsys GUI settings.
Also since we don't have an external Bidirectional buffer on the board I added "arriav_io_ibuf" internally (see aux_buf_iobuf_bidir_nho_i at top.v) - in my legacy design we also used Bidirectional buffer on those signals.
Finally I created a SignalTap with some signals to verify if the example design gets any input video signal.
The design was compiled without any errors but it looks like the display port Rx does not receive any signal since there is no MSA lock (only occasional negative pulses on Rx Aux In - see attached image)
when I program my legacy design I get steady msa lock most of the time and I'm using the same application to configure the GPU to generate same DP signal. Can you please help me find out what is wrong?
- did I forget any important pin assignment or pinout?
- did I change any settings that disrupted the design to receive DP?
Please let me know if you need more data.
Ariel
Hi dlim
Also when running the example design, I opened the NIOS shell command and type "s" as you instructed, unfortunately it was not recognized as a valid command (see attached image)
Please advise if there was precursory action that I had to perform before typing "s"?
Ariel
