16 years agoAnyone ported AN532 PCIe to Arria2GX dev kit?
Has anyone ported the PCIe reference design for App Note 532 to the Arria II GX dev kit - and had the PC host GUI work? If so, can you share the project or any insight? -Thanks
16 years agoHi PeterCH,
thanks for the rapid answer. I don't see a reset_n in my design. And I have some pins you didn't mention: gxb_powerdown_pcie_compiler_0 and pll_powerdown_pcie_compiler_0 (inputs) and rate_ext_pcie_compiler_0 and clock outputs (output). I'm using Quartus 10.0 . Don't you see this signals? Should I try Quartus 9.1 rather than the new version? My clock was connected to F18(p) and F17(n). I will test your locations. Regards, Frederik
