anyone explain the flash programming setting for arria 10, part number 10AX115S2F45I1SG,
- 5 years ago
Hi @APPU_appu,
Thank you for posting and sharing the finding in Intel community forum, hope this message find you well and apologies for the delayed in response.
Per understanding from the previous conversation, please do refer to the following steps here that will bring you through on generating the hex files.
Hope that helps to clarify.Best Wishes
BB
May I know which HEX file should I used? I try both the hex file in software\arria10\mem_init folder and it is telling me that there is overlap data inside the hex file.
Hi @JohnT_Intel
yes with that both file i am geting same error like
i am also facing same issue, i am not able to solve. can u tell me how to generate proper .hex file with nios
- APPU_appu5 years ago
Hi @JohnT_Intel
community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Arria-10-gx-remote-upgrade-generic-flash-access-using-flash/m-p/1260855#M19387
what ever projet you give that project is not having nois ip and generic flash and remote ip also.
If i tried upgrade 18.1 quartus it is showing error in the ip upgradation
- BoonBengT_Altera5 years ago
Moderator
Hi @APPU_appu,
BB- APPU_appu5 years ago
hi @BoonBengT_Altera , @JohnT_Intel
here is the new updatation. Remote IP and Nios Ip also added.
after programing the jic to flash epcql1024 . fpga board it self not boading it showing red error led.below i added my project can u please check that one update.
