13 years agoAnalyzing Simulation result
Hello Friends,
Am new to the Quartus II environments, but i like to know what a the specific part of the software one should go to and dwell on in other to analyse simulation result or output.3 Replies
Quartus is for synthesis, while Modelsim is for simulation.
Here's a tutorial that uses both simulation and synthesis, including code and Tcl scripts to setup both simulation and synthesis http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers, Dave - Altera_Forum
Thanks Dave, i don't have Modelsim installed on my system, but Quartus does produces a logic output... i'm also aware it's output could be viewed as text. That's what am interested in.
--- Quote Start --- i don't have Modelsim installed on my system --- Quote End --- Altera has a free version; Modelsim Altera Edition. Download it and install it. --- Quote Start --- but Quartus does produces a logic output... i'm also aware it's output could be viewed as text. That's what am interested in. --- Quote End --- Viewing generated code is a waste of your time. Write VHDL or Verilog, then write a testbench, and confirm the tests pass in Modelsim. Synthesize the design, along with timing and pin constraints, and generate an output netlist. If timing passes, then run a simulation with the post-place-and-route netlist. Once you have confidence in your design skills, you can generally believe that a design that passes timing can be tested directly in hardware (since post-P&R simulation can take a while). Bottom line is you do not need to read anything Quartus generates. Let *Modelsim* do that for you, and let a computer (via your testbench) test the code too. Cheers, Dave
