13 years agoAnalyzing Simulation result
Hello Friends, Am new to the Quartus II environments, but i like to know what a the specific part of the software one should go to and dwell on in other to analyse simulation result or...
13 years ago --- Quote Start --- i don't have Modelsim installed on my system --- Quote End --- Altera has a free version; Modelsim Altera Edition. Download it and install it. --- Quote Start --- but Quartus does produces a logic output... i'm also aware it's output could be viewed as text. That's what am interested in. --- Quote End --- Viewing generated code is a waste of your time. Write VHDL or Verilog, then write a testbench, and confirm the tests pass in Modelsim. Synthesize the design, along with timing and pin constraints, and generate an output netlist. If timing passes, then run a simulation with the post-place-and-route netlist. Once you have confidence in your design skills, you can generally believe that a design that passes timing can be tested directly in hardware (since post-P&R simulation can take a while). Bottom line is you do not need to read anything Quartus generates. Let *Modelsim* do that for you, and let a computer (via your testbench) test the code too. Cheers, Dave
