GD76's avatar
GD76
4 years ago
altsyncram file for Modelsim Simulation
In Platform Designer, I have dual port RAM. In Modelsim, I have the verilog Block RAM file. That file calls altsyncram. In simulation, I have test bench and the verilog block RAM file. Where do I find the altsyncram file. In my search, I cannot find that file to include in DO file to compile.
  • ShengN_altera's avatar
    ShengN_altera
    Since I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
    Sheng
    ShengN_altera
    Hi GD76,
    Do you have any further update on this thread?
    Sheng
    ShengN_altera
    Hi GD76,
    FYI,
    Altsyncram module is in modelsim_ase/altera/verilog/altera_mf file.
    Using vsim -L altera_mf_ver during simulation will do.
    This command executes searching of altsyncram module in altera_mf library.
    Sheng
