14 years ago
altremote_update - application image mode
I know there are plenty of threads on this subject, I did read them but I am still confuse. I am using a Cyclone III EP3C10F256C8 FPGA and ECPS16.
My intention is to upload the firmware image to an upper region (offset 0x80000 - 1/4th of the flash size) and boot from here, without copying the data to the 0x000000 offset.
---# 1 ---
While reading the documentation(s) of the altremote_ug, I got headaches.
  • the altremote_ug specifies page value (param 4) as the page number (0-15 for EPCS16).
  • an521 specifies the value of this param as the address/4.
Which would be the correct one?
---# 2 ---
If for example I would copy the data from address 0x000.. (as written by the Quartus programmer) to another flash offset, the same image should be bootable from the new offset as well, right?
---# 3 ---
how can I find out what problem the core had while trying to reconfigure?
Thanks for the help!
    Did you try with 0x20000? This is the way I do it in my Cyclone IV project and that seem to work. I thought all addresses was byte addressing.
    --- Quote Start ---
    --- Quote End ---
    Nope, not working.
    Do I need to make use of the watchdog? Can I have just the simple statemachine I described above?
    No, after starting up in Factory image after power-up, it is sufficient to write the boot address for the Application image in parameter 4, write 0 to parameter 3 (disables watchdog) and set the reconfig pin of altremote_update high.
    --- Quote Start ---
    --- Quote End ---
    A billion thanks! It works! (previously when I tried and replied I did something wrong).
    I start getting non-technical skepticism when using Altera after such negative experiences with conflicting userguides/application notes...
    The AN521 clearly says it should be the word addressing without the last 2 lsbs :mad::confused:
    ... from now on every time I have an error I will tend to first blame Altera :-P
    Thanks again!
