16 years agoALTLVDS buffer implementation
I'm using an altlvds_rx receiver in Cyclone III with external PLL. For the buffer implementation I can choose between RAM, MUX and LE. Could there be a reason to make a choice other than resource usa...
16 years agoThanks FvM. So it is the odd deserialization factor. You're right. I use a deserialization factor of 9. What a mistake. Next time I will certainly use even factors, that's for sure.
Do you know if there's any detailed additional information on this topic? Cheers, Ton
