16 years agoALTLVDS buffer implementation
I'm using an altlvds_rx receiver in Cyclone III with external PLL. For the buffer implementation I can choose between RAM, MUX and LE. Could there be a reason to make a choice other than resource usa...
16 years agoWell there's one good reason not to use RAM buffer. It adds a variable data latency to rx_out after a reset or power cycle.
The MUX and LE and they both give a FIXED latency of 3 slow clock periods. The LE buffer implementation uses a lot of resources, so I stick with the MUX buffer implementation. See also another thread I've posted today. Cheers, Ton
