Mikexx
3 years agoALTIOBUF - Enable input buffer dyamic delay chain
I get a series of errors when this feature is ticked in the ALTIOBUF: Cyclone V Quartus 20.1 Error (129036): Output port DATAOUT on atom "DQS_Diff_4:u_DQS_Diff_4|DQS_Diff_4_iobuf_bidir_3qg1:DQS_Di...
EthanLi
3 years agoHi,
This is Ethan from Intel AE team.
I have checked your design and find that the data_out(DQS_in) from the input delay chain connected directly to the output pin in the top design. Once you use the delay chain you should not connect the data_out of the delay chain to the output port of the top level directly, you may connect the data_out to the input of fifo or ddio etc.
I will upload the design compiled successfully.
Ethan
