15 years agoAltera MAXSONAR LVEZ1 sensor
Hi I want to cnnect the LVEZ1 sensor to the de2 board. I have read that the sensor has a serial rs232 format output. But i am not sure how i can connect these to the rs232 module on the de2 boa...
15 years ago --- Quote Start --- module test_rs232(input CLOCK_50, output [17:0] LEDR, output UART_TXD, input UART_RXD, input [1:0] KEY); wire reset; assign reset = ~KEY[0]; parameter DATA_WIDTH = 8; wire [DATA_WIDTH-1:0] received_data; wire [DATA_WIDTH-1:0] transmit_data; wire transmitting_data; wire receiving_data, data_received; wire transmit_data_en; RS232_In u3(.clk(CLOCK_50), .reset(reset), .serial_data_in(UART_RXD), .receive_data_en(1'b1), .received_data(received_data), .data_received(data_received), .receiving_data(receiving_data)); assign LEDR[7:0] = received_data; endmodule //RS232_In.v module RS232_In ( // Inputs input clk, input reset, input serial_data_in, input receive_data_en, // Outputs output reg [(DATA_WIDTH-1):0] received_data, output reg receiving_data, output reg data_received, output baud_clock ); parameter BAUD_COUNT = 9'd434; parameter DATA_WIDTH = 8; parameter TOTAL_DATA_WIDTH = DATA_WIDTH + 2; wire shift_data_reg_en; wire all_bits_received; assign baud_clock = shift_data_reg_en; reg [(TOTAL_DATA_WIDTH - 1):0] data_in_shift_reg; //reg receiving_data; reg prev_receiving_data; always @(posedge clk) begin if (reset == 1'b1) receiving_data <= 1'b0; else if (all_bits_received == 1'b1) receiving_data <= 1'b0; else if (serial_data_in == 1'b0) receiving_data <= 1'b1; end always @(posedge clk) begin prev_receiving_data <= receiving_data; if (receiving_data==1'b1) data_received <= 1'b0; else if (prev_receiving_data==1'b1) begin data_received <= 1'b1; received_data <= data_in_shift_reg[DATA_WIDTH:1]; end end always @(posedge clk) begin if (reset == 1'b1) data_in_shift_reg <= {TOTAL_DATA_WIDTH{1'b0}}; else if (shift_data_reg_en) data_in_shift_reg <= {serial_data_in, data_in_shift_reg[(TOTAL_DATA_WIDTH - 1):1]}; end Baud_Counter RS232_In_Counter ( // Inputs .clk(clk), .reset(reset), .reset_counters(~receiving_data), // Outputs .baud_clock_rising_edge(), .baud_clock_falling_edge(shift_data_reg_en), .all_bits_transmitted(all_bits_received) ); defparam RS232_In_Counter.BAUD_COUNT= BAUD_COUNT, RS232_In_Counter.DATA_WIDTH= DATA_WIDTH; /* Altera_UP_SYNC_FIFO RS232_In_FIFO ( // Inputs .clk (clk), .reset (reset), .write_en (all_bits_received & ~fifo_is_full), .write_data (data_in_shift_reg[(DATA_WIDTH + 1):1]), .read_en (receive_data_en & ~fifo_is_empty), // Bidirectionals // Outputs .fifo_is_empty (fifo_is_empty), .fifo_is_full (fifo_is_full), .words_used (fifo_used), .read_data (received_data) ); defparam RS232_In_FIFO.DATA_WIDTH = DATA_WIDTH, RS232_In_FIFO.DATA_DEPTH = 128, RS232_In_FIFO.ADDR_WIDTH = 7; */ endmodule module Baud_Counter (input clk, input reset, input reset_counters, output reg baud_clock_rising_edge, output reg baud_clock_falling_edge, output reg all_bits_transmitted); parameter BAUD_COUNTER_WIDTH = 9; parameter BAUD_COUNT = 5; parameter BAUD_TICK_COUNT = BAUD_COUNT - 1; //9'd433; parameter HALF_BAUD_TICK_COUNT = BAUD_COUNT / 2; //9'd216; parameter DATA_WIDTH = 9; parameter TOTAL_DATA_WIDTH = DATA_WIDTH + 2; reg [(BAUD_COUNTER_WIDTH - 1):0] baud_counter; reg [3:0] bit_counter; // control baud_counter always @(posedge clk) begin if (reset == 1'b1) baud_counter <= {BAUD_COUNTER_WIDTH{1'b0}}; else if (reset_counters) baud_counter <= {BAUD_COUNTER_WIDTH{1'b0}}; else if (baud_counter == BAUD_TICK_COUNT) baud_counter <= {BAUD_COUNTER_WIDTH{1'b0}}; else baud_counter <= baud_counter + 1'b1; end // control baud_clock_rising_edge signal always @(posedge clk) begin if (reset == 1'b1) baud_clock_rising_edge <= 1'b0; else if (baud_counter == BAUD_TICK_COUNT) baud_clock_rising_edge <= 1'b1; else baud_clock_rising_edge <= 1'b0; end // control baud_clock_falling_edge signal always @(posedge clk) begin if (reset == 1'b1) baud_clock_falling_edge <= 1'b0; else if (baud_counter == HALF_BAUD_TICK_COUNT) baud_clock_falling_edge <= 1'b1; else baud_clock_falling_edge <= 1'b0; end // control bit counter always @(posedge clk) begin if (reset == 1'b1) bit_counter <= 4'h0; else if (reset_counters) bit_counter <= 4'h0; else if (bit_counter == TOTAL_DATA_WIDTH) bit_counter <= 4'h0; else if (baud_counter == BAUD_TICK_COUNT) bit_counter <= bit_counter + 4'h1; end // control all_bits_transmitted signal always @(posedge clk) begin if (reset == 1'b1) all_bits_transmitted <= 1'b0; else if (bit_counter == TOTAL_DATA_WIDTH) all_bits_transmitted <= 1'b1; else all_bits_transmitted <= 1'b0; end endmodule --- Quote End --- The code compiles but there is no ledr's turned on. The code is from here http://www.johnloomis.org/digitallab/rs232/rs232lab.qdoc.html#baud_counter.v http://imageshack.us/photo/my-images/528/img00276201111141211.jpg/ Please let me knoe if u guys see any problem
