16 years agoAltera CycloneIII FPGA PLL problem
The PLL input clock is 27M. It is multipied and output a clock of 270M to supply the ASI IP core. 8 PCB boards are in test and downloaded the same FPGA program. The problem is, 4 out of 8 boards can ...
16 years agoOk, input clock is good, solder joint are good.
Are all devices under test of the same speed? Are the PLL power supplies ok (Vcca and Vccd)? Voltage? Decoupling? Grounding? That's all I can think of. Try some other input- and/or output-frequencies. Does the problem remain? -- Ton
