11 years ago
Altera 5CGXFC3B7U15C8N delay time of a single cell?
I am quite now in the world of the FPGAs. I would like to ask what is the delay time of a single inverter of an Altera 5CGXFC3B7U15C8N FPGA!
I am trying to find some information in the datasheets, but I had no success so far!
Thank you a lot beforehand,
Best regards.
    The FPGA has no gates. So you have to use the LUTs - and you will have to do hand placement to ensure the routing is the same on every compile.
    --- Quote Start ---
    There are luts that can be used for inverters, or any other gates.
    But your ring oscilator is not going to be very reliable on an fpga - it will be highly affected P&R and PVT. You can hand control the placement to get a reasonable level of control, but temperature will just affect the output/
    --- Quote End ---
    My purpose is to measure the temperature changes based on this R.O., so, in that case do you suggest using LUTs or Gates?
    I want to implement a ring oscillator. I thought I could use a chain of inverters-cells that can be found inside the FPGA. So, what can I use for my implementation, when there are no inverterts inside the FPGA?
    That information would have relavence, because the routing would have bigger effect than a single ivnerter. Anyway - inverters do not exist in the FPGA - they become part of any LUT
