12 years agoALTDDIO_OUT. How to overcome restrictions on output data port?
Hello!
In the Double Data Rate I/O Megafunctions datasheet it is said, that DDR output data port of ALTDDIO_OUT ( dataout[] ) should directly feed output pins in top-level design. But in my design I need to feed these outputs to inputs of another block inside my design. That , of course, causes Quartus errors. Is there a workaround for this problem?2 Replies
--- Quote Start --- Hello! In the Double Data Rate I/O Megafunctions datasheet it is said, that DDR output data port of ALTDDIO_OUT ( dataout[] ) should directly feed output pins in top-level design. But in my design I need to feed these outputs to inputs of another block inside my design. That , of course, causes Quartus errors. Is there a workaround for this problem? --- Quote End --- DDR is meant for external interfacing only. Inside fpga there is no ddr support as you can just double your clock. - Altera_Forum
And you can just build it in RTL. The altddio_out is meant to call the dedicated structure built in the I/O cell.
