16 years ago
ALT_INBUF_DIFF in cycloneII
is possible in cycloneII device use 2 pins INPUT for differential rs422 signal?
In quartus2 the differential buffer for cyclone2 is not allowed!
    hi std_logic_vector!
    RS422 is not RS232.
    It is a differential line (2 wires + ground) at level 0-3.3V.
    it is compatible with ecl differential levels, but cycloneII has only dedicated pin for this function.
    I can use the lvds standard on fpga, but it works at 2.5Volt, and i use in this bank register 3 pins at lvcmos level as output (3.3 volt).
    regards
    You may not connect RS422 directly to an FPGA. Even if a differential buffer would exist. RS422 inputs need to have a common mode range of +/- 10V.
    So before interfacing to your FPGA, use a RS422 differential line receiver.
    Regards, Ton
