16 years agoALT_INBUF_DIFF in cycloneII
is possible in cycloneII device use 2 pins INPUT for differential rs422 signal? In quartus2 the differential buffer for cyclone2 is not allowed!
16 years ago --- Quote Start --- in my case it is a "modified" rs422. can lvds pin work at 3.3 volt? --- Quote End --- "modified" RS422, that explains it all :-) Quartus will give an error if you set Vccio to 3V3 and select LVDS as I/O standard. I don't know what happens when you set Vccio to 2V5 in Quartus, but supply your bank with 3V3. I guess there's a big chance LVDS will work, at least with your "modified" RS422. But you don't get any guarantee from my side. If you going to try it, please post the result. Good luck, Ton
