Asaf_Bloch's avatar
Asaf_Bloch
5 months ago
agilex5 stop configuration after vout_mode command
Hallo
I use SmartVID with Agilex5 device,
Configure the Quartus to work with LTC3882 device by analog Device
When try to program the device the process stop after VOUT_Mode command from SDM and 0x14 reply from Analog device.
Get the following message:
Error(18950): Device has stopped receiving configuration data
Error(18948): Error message received from device: External hardware access error. (Subcode 0xC809, Info 0x00010014, Location 0x00000C2E)
Error(18948): Error message received from device: Error while sending VOUT_MODE command,
Error(23925): Debug suggestion: Ensure Voltage Regulator supports this command.
Error(209012): Operation failed
Any advise regarding this issue?
Asaf
1 Reply
  • Farabi_Altera's avatar
    Farabi_Altera
    From the supported VR list(tested) , only LTC3882-1 listed.
    The PMBUS controller should be the same, but can you check below codes in your firmware:
    LTC3882
    PAGE = 0
    VOUT_COMMAND -> sets output 0 only
    PAGE = 1 -> not supported
    LTC3882-1
    PAGE = 0
    VOUT_COMMAND -> output 0
    PAGE = 1
    VOUT_COMMAND -> output 1
    if the firmware used LTC3882-1 on LTC3882 device, this explains the 0x14 reply from Analog Device (command acknowledged, but not supported/incorrect mode")
    regards,
    Farabi
