SDavi9
7 months agoAgilex Migration Issue
I am using a Agilex 5 chip A5EC008BM16AI4S which I am trying to ensure correct migration with the following 2 compatible chips : A5EC013BM16AI4S or A5EC028BM16AI4S. For the pins T22, U22 & V22 so it ...
- 6 months ago
according to my reading, pin connection guidelines clearly state that N.C. pins can be connected either to ground, power, signal trace or left floating when required by migration compatibility. Normally you don't need jumpers. That means that all conditional ground and power pins are connected to the respective rails in migration aware PCB design.
Side remark, migration can also involve pins that are either IO or power/ground, e.g. for many Cyclone series. They get power/ground connection in migration PCB.
Regards Frank
SDavi9
6 months agoThank you for getting back to me !
If I am going to migrate between these chips then a jumper will be required to the supply I mentioned. I would have thought that this was an important thing to document no ?
