Agilex DDR4 Interface Debug
Can you please be more specific with `EMIF Debug Toolkit has been enabled`. ?
External Memory Interfaces Intel Agilex IP has a parameter in Diagnostics Tab.
Disabled : Certainly we dont want this .
Export : EMIF debug interface IP core is not among available IP list in IP Catalog.
I selected Add EMIF Debug Interface and Rerunned the whole flow starting from Generate HDL. When I downloaded the .sof file I could not see any selection in the system console system (Debugger Tools /System Console).
Since the related parameter is under the title Example Design (Diagnostics Tab not Example Design Tab) I generated the example design and will try downloading the resultant sof file .
