Istwok
6 months agoAgilex 9 power
We started a new design based on the Agilex 9
AGRW027R28A2I2V
Our power designer has the following question:
"Can the VCCA_AXA0_1P8 and VCCA_AXA1_1P8 be powered by the same voltage regulator or does each rail need its own separate voltage regulator?
Same with the VCCA_AXA0_1P2 and VCCA_AXA1_1P2, and for the VCCA_AXA0_0P9 and VCCA_AXA1_0P9."
Any insight or experience tying these rails together you can share will be helpful.
Thank you
- Farabi_Altera
I am checking with internal team. I will get back to you.
regards,
Farabi - Farabi_Altera
It is recommended to separate the power to maintain the signal stability for analog components of the FPGA. VCCA_xxx is supplying power to analog blocks of the FPGA(PLL, transceivers etc.)
regards,
Farabi
