ajithb's avatar
ajithb
8 months ago
Agilex 9 Port Synchonization within A Tile
I am currently using Agilex 9 Evaluation Board AGRW014. I am trying to perform synchronization across 4 ports. I connected the sysref request from DRF IP to the respective pin connected to sync of LMK. Once powered ON, i issued the Start Latency Alignment command by writing the basic mode register 0x0400 bit[0] as 0x1. But i am facing the issue of SYSREF Response Error. Please share the proper sequence to be performed to achieve the Synchronization across port. As well as please provide the method or sequence of register writes to achieve proper phase synchronization (DDC NCO sync) over the bandwidth. Please list the things to be taken care while performing synchronization
    • ajithb's avatar
      ajithb
      Thank you. Please provide me the process to achieve good phase matching results across ports since only 1 A Tile is involved so. Please help me in getting the best phase matching results out over the band of 20 GHz. We don't have enough data related to phase matched results of this board over the band.
      • JohnT_Altera's avatar
        JohnT_Altera
        After further checking, please contact your local FAE on further support.
