Serge93
1 year agoAGILEX 7-I R-Tile PCIe Root port : Unsupported Request received after enumeration
hello, I am using the the Agilex 7-I r-tile Dev kit board in PCIe Root Port. After I have done my enumaration when I am doing a Memory Read of one 32-Bits data, I receive a completion with 'Unsuppo...
RongY_altera
Contributor
1 year agoIt looks a mem bar is enabled for use. Somehow the config addr 0x20-27 data does not look right. Normally in a cpu-based test, a mem wr always has a requester id in hdr.
If possible, my suggestion is to set a fpga pcie endpoint design, check the root port parameters from lspci. You may confirm the address base and limit for the device is correct before using it.
Rong
Serge93
1 year agoHello Rong,
The requester ID is fixed in hardware by the R-Tile PCIe IP, you cannot modify it.
I have configured the Memory Base and Limit but not the prefectchabel one.
Knowing I do not want Prefetch access...
Sorry I cannot do your suggestion.
Thank you.
Serge
