Serge93
1 year agoAGILEX 7-I R-Tile PCIe Root port : Unsupported Request received after enumeration
hello, I am using the the Agilex 7-I r-tile Dev kit board in PCIe Root Port. After I have done my enumaration when I am doing a Memory Read of one 32-Bits data, I receive a completion with 'Unsuppo...
RongY_altera
Contributor
1 year agoThanks for the info.
From the RP side, please read config addr 0x10 to see if the bit0 is 0.
Rong
- Serge931 year ago
Hello Rong,
The reading of the address 10h (BAR0) in the Agilex 7 PCIe RP is equal to 00h.
Can you check this write access :
It is supposed to be a Memory Write at address 40000014h of 1DW with the value 00460000h
The Completion is an Error Message IRQ code 31h :
Thank you.
Serge
