Agilex 5 transceiver output clock
Hello Intel team,
We use the transceiver output clock, it CML format.
The CML output consists of a differential pair with
50Ω collector resistors, as shown in Figure 3
Is the Agilex-5 implement this 50Ω collector resistors and what is the VCC voltage?
When interfacing with differential CML receiver, do we need external components other than AC couple capacitors?
Asaf
1 Reply
- WZ2
Hi Asaf,
Thank you for your question.
Yes, the Agilex™ 5 transceiver CML output includes internal 50Ω collector resistors, so no additional external termination resistors are needed. When interfacing with a differential CML receiver, you only need to add AC coupling capacitors.
For recommended connection guidelines and further details, please refer to Intel's official Pin Connection Guidelines (PCG):
WZ
